Water damage mitigation can often be a complex process. And when it comes to Category 3 water damage, the stakes are even higher. This article walks you through the essential steps for achieving effective results.
The IICRC Reference Guide for Professional Water Damage Restoration (known as the IICRC S500 Standard) categorizes water into three groups based on the source and contamination level. Category 1 involves clean water from a sanitary source, while Categories 2 and 3 involve progressively more contaminated water. Here are brief explanations of those two more severe categories:
Since Category 3 water damage is the most severe, it can have serious implications. The water may carry human waste, pesticides, heavy metals, regulated materials, or other pathogenic or toxigenic substances. These dangers can cause infections, respiratory problems, allergic reactions, and worsening of existing health conditions.
Learn more: Difference Between Water Damage Categories 2 and 3
The best way to do this is to use a high-quality floor plan app, such as magicplan. This invaluable tool will streamline the documentation process by allowing you to:
- Create a custom form or checklist for initial water damage assessment visits
- Digitally sketch each job site’s water-affected rooms and water-intrusion points in real time
- Use comprehensive, built-in documentation features (360-degree panoramas, images of water damage, photos of moisture-meter or thermo-hygrometer readings, descriptive notes, and sketch-enhancing objects) to describe the extent of water damage
Create and share a digital water damage assessment report to facilitate communication with others
The collaborative aspect is particularly beneficial when dealing with complex, Cat 3 water damage projects. In these situations, multiple experts may need to contribute their insights to ensure a thorough and accurate assessment. A good floor plan app makes this kind of collaboration quick and easy.
Can you really do that? Absolutely! But only if your documentation app is designed to integrate with Xactimate®. For example, the magicplan floor plan app allows you to export your documentation to Xactimate® quickly with just a few taps.
Once you have imported your initial documentation into Xactimate, the next step is to create a detailed mitigation estimate outlining the scope of work and associated costs. This estimate should include a thorough assessment of the damage; a breakdown of your water damage mitigation plan; an itemized list of all required tasks, personal protective equipment, materials, and drying equipment; and the complete cost of mitigation that you are proposing.
Providing your client and their insurer with a transparent estimate serves three key purposes:
1. It instills confidence.
2. It ensures clear expectations throughout the mitigation process.
3. It serves as a blueprint for the mitigation process, guiding technicians and project managers throughout the project.
Tip: Do This as You Build Your Estimate
Closely review the WTR (Water Extraction and Remediation) category in Xactimate, and make sure to include all relevant line items (e.g., extracting contaminated water, disposing of contaminated water, removing contaminated items and debris, performing flood cuts, removing sludge, HEPA-vacuuming demolished areas, completing heavy-duty sanitizing). The list of available line items is long, and you want to make sure you don’t miss any that apply to the specific project you are estimating. So, taking time to look at all WTR line items is a smart strategy. In fact, the more familiar you become with those, the better you’ll understand how to estimate intricate projects and unique scenarios.
The IICRC S500 Standard, mentioned earlier, describes the procedures to be followed and the precautions to be taken when performing water damage restoration in residential, commercial, and institutional buildings, and the systems and personal property contained within those structures.
Note: This standard is currently under revision (as of Spring 2024).
Ensuring the health and safety of everyone at the job site is imperative when dealing with Category 3 water damage. Before your company begins any work, meet with the property owner and explain potential health risks that exist at the job site. Insist that all occupants remain offsite until your mitigation efforts are completed. Then be sure your trained crew follows established health and safety protocols, including wearing appropriate personal protective equipment, establishing adequate ventilation, and implementing appropriate decontamination procedures to minimize exposure risks.
Professional Training Is Critical
Any technicians performing Category 3 water damage mitigation must be trained to be aware of exposure risks and to follow procedures for safe cleanup. (For example, flood cleanup can be particularly dangerous for the health and safety of workers.)
Compared to properties with less severe water damage, a Category 3 job site may require more advanced techniques to mitigate damage effectively and to prevent mold growth and bacterial contamination. These techniques may involve greater use of infrared cameras to detect hidden water damage and mold growth; more detailed planning to determine the best drying strategy; and the use of higher-capacity equipment and strong antimicrobial treatments to thoroughly dry and disinfect affected areas. Implementing these advanced techniques can significantly improve the effectiveness of the mitigation process and minimize the risk of secondary damage.
Learn more: Pro Tips for the Drying Process
Collecting comprehensive documentation is essential as your technicians move through mitigation work. The ideal way to address this is to have them use the same floor plan app that you employed for your initial documentation. This way, they will be able to document equipment usage and placement, record moisture levels, maintain drying logs, and capture before-and-after photos.
All of these details can be consolidated in a single mitigation report – a document that will serve as valuable evidence for regulatory compliance and for Category 3 water damage insurance claim purposes.
After mitigation is completed and the job site passes a thorough inspection, you can begin preparing for any needed restoration work. So, it’s time to whip out your floor plan app once again, to get the ball rolling.
You can use the app to:
Effective management of Category 3 water damage mitigation requires a systematic approach. This involves understanding the implications of Category 3 water damage, gathering initial documentation, exporting your documentation to Xactimate, creating an estimate, adhering to industry guidelines, prioritizing health and safety, employing advanced techniques, and documenting the mitigation process. Following these steps will help ensure safe, thorough, and successful mitigation, so you can restore properties to their pre-loss condition.
CHECK OUT THESE RELATED ARTICLES:
How to Build Effective SOPs for Any Water Damage Restoration Job
Zuzanna Geib
Team Lead Marketing
