If you are a restoration contractor, you may often be faced with the task of initiating rapid and complete structural drying inside a water-damaged property. In this type of scenario, employing effective techniques is critical to prevent structural deterioration and avoid mold growth. One key method to consider is the use of a drying chamber. In this article, we offer insights and tips to help you maximize its effectiveness.
A drying chamber provides a controlled environment that is conducive to rapid drying of structural materials (drywall, joists, subfloors, etc.). By encapsulating the water-damaged area, the chamber concentrates the effectiveness of high-powered air movers and dehumidifiers to optimize moisture removal. This works to accelerate the restoration timeline significantly, while also minimizing energy consumption.
In addition, drying-chamber containment helps prevent cross-contamination between the affected area and unaffected spaces. The property owner and occupants will appreciate the fact that you are protecting other areas and ensuring safe air quality.
Your plan to use a drying chamber can also impress the adjuster involved with the project – especially if you explain how the chamber will reduce the project’s completion time and cost. For example, you can emphasize that it will help you avoid wasting time and resources drying unaffected air and unaffected structural materials. You can also point out that the drying chamber will play a pivotal role in preventing mold growth, which can escalate quickly, worsen structural damage, and cause dangerous health hazards. (Plus, having to complete a mold remediation process would increase the project’s overall cost.)
Yes, It Really Works!
When you construct a drying chamber, you dramatically reduce the airspace of your work area. This means you can achieve better and faster results. So, think about how you can use one for any area size – even closets, cupboards, and other small cavities.
You can construct a drying chamber with heavy-duty plastic sheeting or a specialized system specifically designed for this purpose. With the right materials and a bit of practice, you will find that containment setup can be quick and easy.
Once you have finished fully enclosing and isolating a water-damaged area, then you’ll be ready to position and deploy your drying equipment to initiate the drying process. You may also opt to warm the air within the targeted space, as another way to speed up moisture removal.
Sure, the whole process may seem a bit intimidating at first. But as you become more comfortable doing it, you will buildconfidence in your ability to erect containments at future job sites.
LEARN MORE: How to Set Up a Solid Containment for Water Damage Jobs
.gif?width=832&height=607&name=drying%20chamber%20iPAD%202%20(Website%20Pages).gif)
NOTE: Using a drying chamber is all about controlling the balance of airflow, evaporation and dehumidification in a defined and contained area. We recommend undergoing professional technical training, so you can learn and apply industry-wide best practices.
A drying chamber can serve as an invaluable strategy for efficient and thorough structural drying. By creating a controlled environment conducive to accelerated drying, this type of enclosure streamlines the restoration process, minimizing disruption and mitigating further damage. If you focus on careful planning, proper setup, and correct use, you can ensure that every drying chamber delivers optimum results.
Sales Consulting Manager
