/Inside magicplan
If you’ve been in restoration long enough, you already know the routine. You’re walking off a job, and you know work was done, but the estimate doesn’t capture it all. Things get missed—not because they weren’t done, but because there wasn’t time to sit down and scope it right, or because the field notes weren’t clear, or the photos weren’t tied to the sketch. Now you’re chasing paperwork, hoping the adjuster sees what you were trying to show.
magicplan Pro Estimate+ was built to fix this. It gets you from the jobsite to a complete estimate without missing the details. It’s not about making up numbers or overbuilding files. It’s about capturing everything that actually happened—and getting it in front of the people who need to see it.
An estimate is not just a number. It’s the full picture of what happened on the job. Bobby Paine (from Epic Estimates) explained it best: a good estimate is easy to read, structured so it’s easy to interpret, and it’s submitted early—while the job is still fresh—not later when it’s urgent.
A good estimate includes the stuff that the adjuster would usually kick back. That right-hand column—where they put their homework—it needs to already be answered:
And it needs to be presented in a way that’s simple and clean. If it’s messy, or if the story isn’t there, it’s going to get picked apart. And that leads to delays, frustration, and less money in the end.
We talked through the common issues—and they’re not new. Everyone’s seen them:
These issues don’t just slow things down. They result in real dollars left on the table—and time wasted chasing things that should’ve been clean the first time.
magicplan Pro Estimate+ gives you two ways to get your estimates done—without missing a step. At its core, it includes everything from our core estimating product, magicplan Pro Estimate.
With magicplan Pro Estimate, you can:
magicplan Pro Estimate+ takes it one step further. It includes all of that—and adds the ability to submit your project directly to a team of expert estimators from Epic Estimates. With a tap inside the app, you hand off your scoped project and receive a clean, carrier-compliant Xactimate® or CoreLogic/Symbility estimate in return.
So instead of writing the estimate yourself, your documentation gets turned into a detailed, polished file built by folks who know what carriers want to see.
You do the walkthrough. Capture everything. And the estimate gets done—right.
With magicplan Pro Estimate+, your file reflects the actual job:
The estimate is no longer something you hope sticks. It becomes part of the process that runs like everything else in the job.
As Bobby explained in our conversation, the difference can be 17% to 31%. That’s not fluff. That’s because:
And it’s not just about more money. It’s about better files:
And once you’re using it regularly, you start noticing how much time you used to waste fixing things that should’ve been right the first time.
Here are a few preview examples of real-world estimates—one water damage estimate (built on IICRC S500), one smoke and fire damage estimate (following S700 guidelines), and one for general repairs. Each estimate is structured using industry-recognized formats for Xactimate® estimates and CoreLogic/Symbility estimates, making sure they meet carrier expectations and reflect the full scope of work:
Adjusters want to see what happened. They don’t want a mess of photos with no context. They want a sketch with room names that match the scope. They want to know what was done and why.
That’s what these estimates do. You send them in, and they speak for the job:
You don’t get pulled into re-explaining the job. You just move on.
| ❌ Before: | ✅ Now: |
| You scoped in a rush or from memory | The tech walks into the job with magicplan |
| Your estimate came together slowly and missed stuff | Everything—sketch, photos, notes—is captured once |
| You were hoping it wouldn’t get pushed back | With magicplan Pro Estimate+, you get properly formatted estimates |
| Adjusters had questions, and you were stuck replying | The file is ready to send |
| Payments got delayed or trimmed | You stay focused on the work, not chasing estimates |
With magicplan Pro Estimate+, estimating becomes part of your job workflow—not a bottleneck. The field team captures the job. The estimate gets done properly. And you stay focused on doing good work and getting paid fairly.
Learn more at magicplan.app/estimate/pro-plus
Andreas Böhm
CEO
