When a catastrophic (CAT) event strikes — whether it’s a hurricane, flood, wildfire or tornado — you are suddenly thrust into a high-pressure environment. The volume of claims skyrockets, homeowners are desperate for help, and insurers demand rapid, accurate estimates to get the recovery process underway. Estimating during CAT events is fundamentally different from routine restoration work, and mastering this fast-paced process is essential for your restoration company’s success and your customers’ peace of mind. Here’s how you can prepare, adapt, and work smartly to estimate quickly and compliantly during CAT events.
Estimating for CAT losses is a world apart from the detailed, methodical approach you might use for a single water damage cleanup or fire restoration job. In a CAT scenario, speed and compliance take precedence over exhaustive detail. You’re often dealing with:
Due to these factors, CAT estimates are typically less granular. You’ll rely on broad, guideline-driven coding rather than itemizing every minor detail. (Remember: Coding must align with FEMA or insurer standards, which often means using specific line items and descriptions that may differ from your day-to-day estimating. The focus is on rapid, compliant documentation, not exhaustive scoping.)
What You Can Prepare in AdvancePreparation is your greatest ally when CAT season looms. The more you can standardize and template your estimating process before the next CAT disaster strikes, the faster and more accurately you’ll be able to respond. Here’s what you can set up ahead of time:
By having these resources ready, you can hit the ground running, regardless of the scale or chaos of the event.
In a CAT event, turnaround time is everything. The insurer, catastrophic insurance adjuster and property owner connected to each job site are all waiting on your estimate to move forward with approvals, payments and repairs. The longer it takes to generate and submit a compliant estimate, the greater the risk of delays, disputes or even lost work.
That’s why it’s crucial to produce estimates that meet insurer or FEMA requirements before you leave the job site. This means:
- Capturing all required visuals and documentation in one visit.
- Coding the estimate according to the latest CAT and FEMA guidelines.
- Generating and sharing the estimate digitally, on the spot, so there’s no lag between fieldwork and office processing.
Not only does this streamline your workflow, it also reduces errors, omissions, and the need for costly revisits. With the right digital tool, you can complete the entire process quickly at each damaged property.
You can estimate quickly and accurately during CAT events if you have a professional restoration field app. For example, the magicplan app offers all of the following benefits:
One of the biggest misconceptions about CAT estimating is that you need to capture every detail of the property. In reality, what matters most is:
You don’t need to conduct a full, room-by-room scope walk or itemize every minor repair. Focus on the essentials, document them clearly, and code your estimate according to CAT guidelines. This approach is not only faster, but also aligns with what insurers and FEMA expect during high-volume events.
Estimating during CAT events is about working smarter, not harder.
By understanding the unique demands of CAT estimating, preparing in advance, and leveraging a digital tool like magicplan, you can deliver fast, compliant, and visually documented estimates. This approach meets the urgent needs of insurers and property owners, while also positioning you as a reliable, efficient partner in the recovery process. With the right preparation and technology, you can turn the chaos of CAT events into an opportunity to shine as a disaster restoration professional.
Use the magicplan Pro Estimate+ powered by Epic Estimates. You can send any scope to magicplan and get a ready-to-go, carrier-compliant estimate built by an expert using Xactimate or Cotality (formerly CoreLogic/Symbility) software. Schedule a call with our sales team today to learn more about this unique service.
/Inside magicplan
/Integration
Sales Consulting Manager
