If you’re a professional restoration contractor, you may often need to create residential mold reports. Thorough, accurate reports serve as written evidence, which is essential for verifying insurance claims, determining any restoration work that is needed, and getting paid for completed work. So, let’s review some best practices for developing a report.
Mold is a type of fungus that thrives and spreads in moist environments where organic matter is present. Its growth not only damages building materials, it also releases allergens and toxins into the air, posing health hazards to workers and occupants. Therefore, timely remediation is crucial to prevent further spread and mitigate potential health risks.
How Does Mold Grow?
Wherever moisture is present, mold can multiply rapidly. Spores will begin to form in as little as 24 hours after water damage occurs, and will spread over time. That’s why customers and insurers will depend on you to know how to remediate mold quickly.
Prior to starting your mold and moisture inspection, make sure the residential job site is safe to enter. If the residence has sustained any damage, check for any electrical hazards, fire hazards and gas leaks. You may even need to have the electric and gas services turned off before entering the home. If you suspect standing water is present inside, be sure to put on sturdy, slip-resistant shoes. You should also guard yourself with appropriate personal protective equipment (PPE), including eye protection, skin protection, and a respirator that filters mold spores.
Overall, you’ll want to adhere to the Institute of Inspection Cleaning and Restoration Certification (IICRC) S520 Standard during any interior inspection where mold might be present. This standard describes the exact procedures to be followed and the precautions to be taken in residential settings.
Once you are prepared to enter the home, you’ll need to conduct an in-depth inspection. This will give you a clearer picture of the cause of mold, the impact on the home and occupants, and the type of mold remediation process that will be required. Be sure to include an adequate description for each type of visible damage you find (where is it, what is it, how bad is it).
TIP: A mold and water damage inspection typically starts from the uppermost area inside a home and works downward.
Again, refer to the S520 Standard, which provides a framework for conducting a comprehensive assessment. (It also covers other key steps, including moisture measurement, sampling, documenting findings accurately, remediation planning, execution, and post-remediation verification.)
Modern technology has revolutionized the way restoration contractors identify mold presence and its moisture sources. Instruments such as moisture meters, thermo-hygrometers, and thermal cameras enable precise detection of moisture levels and hidden mold colonies in concealed spaces. These tools empower contractors such as you to pinpoint problem areas swiftly and accurately, facilitating targeted remediation efforts.
Among the many tools available to mold remediators, a floor plan app stands out as an invaluable asset for documenting mold presence. An intuitive app, such as magicplan, allows you to conduct digital mold and moisture mapping, annotate problem areas, add photos, recommend work to be done, and track progress throughout the remediation process. These steps allow you to produce detailed work reports, which make it easier for you to get paid by insurers.
A good app will also allow you to customize forms, checklists and price lists specific to the type and scope of damage.
Plus, if your floor plan app offers seamless integration with other technologies, such as Xactimate®, that helps you streamline data collection even further and enhance overall efficiency.
A high-quality floor plan app will enable you to sketch a floor plan, and then use that plan to create an initial report. Here’s how to build it:
- Your name (the person who is writing the report), along with your title and company name
- The date on which you are preparing the report
- Name of the property owner (claimant)
- Details of the property – i.e., location, type of property, age of property
Later, you can also create a mid-project report and, of course, a final report.
Combating mold requires a multifaceted approach – one that involves understanding the fundamentals of mold growth, employing proper safety protocols, conducting a thorough and proper mold inspection, equipping yourself with modern mold-detection tools, and using a floor plan app for comprehensive documentation. Through these concerted efforts, you can safeguard both the structural integrity of homes and the health of occupants against the pervasive threat of mold.
One Dozen Helpful Tools for Finding and Documenting Water Damage
Head of Product
