/room-mockup_blog_2023160.webp?width=727&height=409&name=room-mockup_blog_2023160.webp)
When it comes to detecting water damage, your knowledge, skills and tools are valuable assets. But are you also using an ideal asset for documenting your findings? Read on to learn how a multi-purpose mobile floor plan app can help you save time AND create thorough documentation.
The key to a successful career as a water damage claims adjuster is quite simple: a higher number of closed claims means more income earned. So, how do you optimize your earnings? It all depends on your ability to work quickly and accurately to resolve the maximum number of claims.
This is especially true when you are out in the field, investigating interior water damage claims at residential properties. Every investigation requires proper documentation. Yet, as you know, document creation, submission and management are steps that typically take a lot of time to complete.
Each time you investigate water damage at a residential property, you need to accomplish several tasks related to documentation. So, you’ll want to make sure your Android or iOS mobile device is equipped with a high-quality floor plan app. This versatile app will enable you to complete multiple steps in a short amount of time:
Using a floor plan app for sketching will save a lot of time. To start a new sketch, simply do the following:
Once your sketch is finished, you can highlight your inspection observations by inserting additional details. These can be objects (cabinets, furniture, appliances, etc.) and also descriptive annotations, such as:
An accurate report will serve as written evidence that you completed an inspection. The key to creating one efficiently is to make sure you have a floor plan app with built-in reporting capabilities. This will enable you to convert any floor plan sketch into a detailed water-damage inspection report. You can do this right at the jobsite, after you complete your investigation. Then you can share your report electronically with the policy owner and the insurance company before you leave the property. That way it’s done that same day and not hanging over your head. Plus, you’re one step closer to closing that claim and getting paid.
Here’s what you’ll be able to accomplish in a short amount of time:
The end result will be a complete and professional-looking PDF report – one that is informative and easy for your client to understand. That’s important, for solid reporting can enhance your credibility as an expert and reliable adjuster.
/blog-2nd-adjuster_scope%20water%20damage.webp?width=727&height=409&name=blog-2nd-adjuster_scope%20water%20damage.webp)
A good floor plan app with an estimating feature will give you the power to produce accurate estimates effectively and efficiently, right on your smartphone or tablet. This process is much faster and simpler than writing an estimate by hand. It also prevents errors caused by manual calculations. That means you will make fewer mistakes and never enter the same information twice. Plus, you will be able to create accurate estimates in a matter of minutes, not hours.
/blog-3rd-adjuster_scope%20water%20damage-%20estimation.webp?width=800&height=450&name=blog-3rd-adjuster_scope%20water%20damage-%20estimation.webp)
When you create residential water-damage documentation digitally in a single app, document submission becomes much more efficient. You can email finished documents instantly to the appropriate parties.
Does your floor plan app offer the option of unlimited cloud storage? Fantastic! That’s a good thing. It means you’ll be able to store all of your documentation in the cloud – with no storage-limit restrictions. Every single document will be safe and secure, and also easily accessible for future reference.
When you work in the field as a water damage adjuster, a good floor plan app is your best asset for proper documentation. This type of app allows you to visualize property inspections straightaway, quickly produce and share high-quality reports and estimates, and leverage convenient, cloud-based document management. Use your app regularly to boost your bottom-line performance!
Read More:
How to Spot Water Damage in a House: One Dozen Helpful Tools for Finding and Documenting Water Damage
Head of Product
