If you’re in the market for air movers, this brief guide is designed to help you. But it has an intriguing twist: Each air mover we mention has an out-of-the-ordinary feature that could be beneficial for your business. Keep reading to discover what makes these models worth considering – and also to see some sage advice for selecting and using commercial air movers.
PHOENIX Focus II Compact Axial Air Mover
Designed to be the most compact and portable fan in its class, this dual axial air mover can be transported easily from location to location. It is half the size of standard low-profile air movers (just 21″ x 8-1/4″ x 9-3/8”) and weighs only 15.5 pounds. This reduces the weight that technicians have to carry, to help protect them from injuries. Plus, rugged, molded-in handles give users solid control when packing, unpacking and moving the Focus II. Therefore, if portability is a primary goal, this might be the right air mover for you.
Applications:
DRI-EAZ Stealth AV3000 Axial Air Mover
“Stealth” is a perfect name for this model because it features low-noise Stealth™ fan blades for quieter operation. In fact, the sound level, on average, is just 58–72 dB. For reference, normal conversation averages around 60-70 dB. So, this air mover operates with about the same amount of sound. In fact, the manufacturer claims that no other axial fan delivers quieter operation AND long-throw-high velocity airflow. That means this unit is ideal for job sites where maximum noise control is an important objective.
Applications:
XPOWER P-830H-BLUE Centrifugal Air Mover
If you have ever used a suitcase that has a telescopic handle and smooth-rolling wheels, then you know how that combination can be super beneficial. Well, this air mover features that same luggage-style design for roll-and-go ease. Just pop up the handle and tote it anywhere. No lifting and carrying required.
Applications:
Similar Models with Lower Horsepower:
It's crucial to focus on leading brands that are known for their high quality and reliable performance. The PHOENIX, DR-EAZ and XPOWER brands certainly meet those criteria. Other popular brands include B-Air, Soleaire and Maxx Air.
Of course, portability, quiet operation and easy handling – offered by the three models we listed above – are attractive features. But you’ll want to consider other important attributes as well:
Incorporating a variety of commercial air mover models into your operation will provide the flexibility you need to tackle any job. These can include a combination of centrifugal and axial air movers. Plus, you may need specialty models such as low profile air movers (e.g., floor blower or floor drying fan units, or carpet dryer / carpet fan units)
Any time you put your air movers into action, be sure to document their use by following the steps below.
Moisture mapping is a critical first step in water damage restoration, and involves pinpointing the exact locations and extent of moisture within a structure. This process is essential because it guides restoration efforts, ensuring that drying equipment is effectively placed and that all wet areas are addressed, preventing mold growth and structural damage.
For example, here is how you can perform moisture mapping with the magicplan app:
For example, the magicplan app has an object library for this task. It allows you to place pre-made objects on your job-site sketch to show placement of water mitigation equipment. The app’s available objects include air movers and dehumidifiers, but you can also create custom objects for other types of equipment.
After positioning your air movers, it's essential to track and record their performance. A good documentation app, such as magicplan, will help you perform this task efficiently as well. Doing so helps you maintain accurate records for effective project management, client communication and finalization of insurance claims.
Why and How to Maximize Air Movement During Water Damage Cleanup
Head of Product
